				Again and again to login
				Verfasst: Mi 5. Feb 2014, 11:13
				von Opelmad
				I think there is a small problem with the forum.
I need by every visit to login, evey day many times.
Are there more friends with this problem ?
				Re: Again and again to login
				Verfasst: Mi 5. Feb 2014, 12:33
				Hello Andre,
same problem here. It's since we've moved to new Hardware. Normally there shouldn't be any change in the software but somewhere in the configuration has occured a change. I haven't found it yet.
Sorry for the inconvenience
				Verfasst: Mi 5. Feb 2014, 16:51
				von Maiki66
				Ja das ist mir auch schon aufgefallen.
Nervt ein bissl, hoffentlich funkt das bald wieder.
blitzmäßige Grüße
				Verfasst: Fr 7. Feb 2014, 15:41
				von Opelmad
				Do you have already check the cookie settings?
For exemple
Cookie domein: opelmodellforum.de
cookie naam: phpbb3_OMF
Cookie pad: /
You can not place 3 dot's in de cookie name like .phpbb3.OMF.
				Verfasst: Sa 8. Feb 2014, 20:59
				Hello Andre,
Cookies was one of the first things, I've checked. Looks all fine.
Have the problem with another board, too. Since moving to a new hardware and transferring all the files both phpBB-Boards show this effect. Haven't found a solution yet...
Greetings, Alex
				Verfasst: Mo 10. Feb 2014, 21:45
				von Botze
				ja das Problem hab ich auch....teilweise muß ich mich sogar neu einloggen wenn ich einen Beitrag schreiben möchte....
nerft zwar einwenig aber wird sich bestimmt wieder ändern...
				Verfasst: Sa 15. Feb 2014, 18:23
				von Opelmad
				I have don a search on internet and it must be the cookie settings.
https://www.phpbb.com/kb/article/fixing ... -settings/
				Verfasst: Sa 15. Feb 2014, 23:18
				Hi Andre,
thanks for your help:
As I wrote some days ago:
Alex hat geschrieben:Cookies was one of the first things, I've checked. Looks all fine.
This is your board URL:
http://example.com/phpBB3
we have:
http://opelmodellforum.de/phpBB3
Your cookie settings should be:
Cookie domain:
.example.com (Note the dot at the beginning!)
we have:
.opelmodellforum.de
Cookie name:
cookiename_example (This can be anything what you want, make it original.)
we have:
omf_the_cookie
Cookie path:
/ (Note that this is always a slash, it doesn't matter what your board URL is)
we have:
So... anyone any more ideas?
(Have the same problem with another phpBB3-Board on the same server since moving to new hardware.)
Greetings, Alex
				Verfasst: Sa 15. Mär 2014, 14:56
				Hello,
it seems, we've found a solution. Am just testing but it looks like the cookies are read again by the system...
				Verfasst: Sa 15. Mär 2014, 16:35
				It looks ok now - scheint wieder in Ordnung zu sein! Danke!!!
