Again and again to login
I think there is a small problem with the forum.
I need by every visit to login, evey day many times.
Are there more friends with this problem ?
Re: Again and again to login
Hello Andre,
same problem here. It's since we've moved to new Hardware. Normally there shouldn't be any change in the software but somewhere in the configuration has occured a change. I haven't found it yet.
Sorry for the inconvenience
Ja das ist mir auch schon aufgefallen.
Nervt ein bissl, hoffentlich funkt das bald wieder.
blitzmäßige Grüße
blitzmäßige Grüße
Do you have already check the cookie settings?
For exemple
Cookie domein: opelmodellforum.de
cookie naam: phpbb3_OMF
Cookie pad: /
You can not place 3 dot's in de cookie name like .phpbb3.OMF.
For exemple
Cookie pad: /
Hello Andre,
Cookies was one of the first things, I've checked. Looks all fine.
Have the problem with another board, too. Since moving to a new hardware and transferring all the files both phpBB-Boards show this effect. Haven't found a solution yet...
Greetings, Alex
Greetings, Alex
ja das Problem hab ich auch....teilweise muß ich mich sogar neu einloggen wenn ich einen Beitrag schreiben möchte....
nerft zwar einwenig aber wird sich bestimmt wieder ändern...
I have don a search on internet and it must be the cookie settings.
https://www.phpbb.com/kb/article/fixing ... -settings/
Hi Andre,
thanks for your help:
we have: http://opelmodellforum.de/phpBB3
Your cookie settings should be:
Cookie domain: .example.com (Note the dot at the beginning!)
we have: .opelmodellforum.de
Cookie name: cookiename_example (This can be anything what you want, make it original.)
we have: omf_the_cookie
Cookie path: / (Note that this is always a slash, it doesn't matter what your board URL is)
we have: /
So... anyone any more ideas?
(Have the same problem with another phpBB3-Board on the same server since moving to new hardware.)
Greetings, Alex
As I wrote some days ago:Opelmad hat geschrieben:I have don a search on internet and it must be the cookie settings.
This is your board URL: http://example.com/phpBB3Alex hat geschrieben:Cookies was one of the first things, I've checked. Looks all fine.
we have: /
Greetings, Alex
Hello,
it seems, we've found a solution. Am just testing but it looks like the cookies are read again by the system...
It looks ok now - scheint wieder in Ordnung zu sein! Danke!!!
